Message 1 of 2
BT Virus Protect
Hello
Geting very annoyed Virus protect on my PC keeps saying it is deactivated it then takes my to a webpage that will not accept my log in i have done a deep uninstall and installed a fresh download twice now and it still keeps deactivating
1 REPLY 1
Message 2 of 2
Re: BT Virus Protect
My advice and that of others on the forum would be to uninstall BTVirus Protect. It can cause problems on some computers and is a resource hog. It always seems to be one update away from another problem. Do a search of the forum to see the problems. There are far better free antivirus programs available such as Avast Free and AVG Free and if you are a Windows user Microsoft's on board antivirus is now getting good reviews.
If you do want to uninstall BTVirusProtect use this guide and make sure you use the BTVirus Protect/McAfee removal tool after you have restarted your computer.
http://bt.custhelp.com/app/answers/detail/a_id/13523
If you do uninstall BT Virus Protect make sure that you install another AV product or activate Windows onboard antivirus if your version of Windows supports it.
