Message 1 of 9
Broadband Dropping
Hello,
My broadband continually drops on a daily basis, i have done the usual line test, broadband test, checked all the cables, turned off and restarted but still the same issues. any advice would be appreciated
8 REPLIES 8
Message 2 of 9
Re: Broadband Dropping
in order for the forum members to help please can you post the stats from your router (if hub enter 192.168.1.254 in your browser) and if  HH5 then go to troubleshooting then helpdesk and if HH6/SH2 then advanced settings then technical log information .
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
Are you using the test socket with a filter to see if that improves your connection speed and stability
Someone may then be able to offer help/assistance/suggestions to your problem
Message 3 of 9
Hello,
tried the quiet  line test and no issues there, run troubleshooter testing of broadband and line and nothing there either
Product name:Smart Hub
Serial number:+088044+1806003000
Firmware version:v0.09.06.25010-BT
Firmware updated:Wed Jun 10 19:35:00 2020
Board version:01
DSL uptime:0 days,17 Hours08 Mins52 Secs
Data rate:14.083 Mbps / 45.866 Mbps
Maximum data rate:14.231 Mbps / 46.790 Mbps
Noise margin:6.2 / 6.3
Line attenuation:8.9 / 9.5
Signal attenuation:8.8 / 9.5
Data sent / received:1.5 GB / 6.6 GB
Broadband username:[email protected]
BT Wi-fi:Activated
2.4 GHz wireless network name:BTHub6-F356
2.4 GHz wireless channel:Automatic (Smart Wireless)
5 GHz wireless network name:BTHub6-F356
5 GHz wireless channel:Automatic (Smart Wireless)
Wireless security:WPA2
Wireless mode:Mode 1
Firewall:Disabled
MAC address:94:6A:B0:41:70:16
Software variant:-
Boot loader:0.1.6-BT (Fri Sep 9 10:05:09 2016
Message 4 of 9
are you using the master socket?  which master socket do you have
Message 5 of 9
The one I'm using is figure 5, I have taken the plate off and tried the test line for phone, no issues
Message 6 of 9
if you have connected a filter to test socket and that has stopped internet dropping when making/receiving a call then you have a faulty faceplate which need replaced.  probably get one ebay/amazon
Message 7 of 9
Spoiler
Only tried the phone via the test socket but I have just connected the filter and tried the phone and broadband. Phone working fine but no Internet connection, would you assume still an issue with the plate
Message 8 of 9
When you remove the front plate shown by red arrow you then have to remove the middle section shown by yellow arrow to the have access to the test socket shown by black arrow.
if you don't remove the middle section you are not using the test socket
Message 9 of 9
Okay got you know both working fine off the test socket
