Message 21 of 406
Re: Can't update from McAfee to Norton
Having the same issue Also the email was a bit strange as it said I can now start watching Norton
Message 22 of 406
I've got exactly the same problem: webpage opens with server error at the top then a huge string of text.  I contacted Norton Support who said nothing to do with them and it has to be BT who sort it, as it's "their account" that is faulty.
Message 23 of 406
Hi @tomsk52uk and @markflip and welcome to our community.
I've moved your posts so we have all the questions on the same thread. We're investigating these issues with Norton and will update this thread as and when we get anything further.
Cheers
David
Message 24 of 406
Re: Important updates to your virus and password protection
Hi @Ian24 ,
Can you confirm the Windows 11 build number for Norton to investigate further? We’ve been in touch with Norton and that is what they have asked for.
Cheers
David
Message 25 of 406
Hi DavidM, not sure what you mean by build number? Thanks Ian24
Message 26 of 406
Goto Settings->System->About (might need to scroll down).   Second block down is Windows Specification. Fourth line down should be OS Build followed by a number. I think this number is what they are after.
Message 27 of 406
Re: bt virus protect change to Norton
Hi @momo ,
It looks like you’re facing the same login issue which we’re aware of and working to fix quickly. Once that’s fixed which we’ll let you know on this Forum, you’ll be able to click the “Manage” button and continue to complete the installation. In the meantime, if you’ve got the McAfee version of BT Virus Protect on your PC or Mac or Android, it will continue to work as normal. Don’t worry about the email talking about the Norton subscription, you won’t be charged - we know it’s a bug which we’re also fixing.
Cheers
David
Message 28 of 406
Hi DavidM,
The OS Build number is 22000.318
thanks
Ian
Message 29 of 406
Thanks @Ian24 . I'll pass that on.
Cheers
David
Message 30 of 406
Hello David
Thank you , and I see that I am not the only one having problems. Will  now await the solution an then complete the download.
