Message 151 of 406
Re: Can't update from McAfee to Norton
Hi I’m afraid it seems they don’t really know what is happening so blame it on your equipment told me I was the only one that’s having a problem till I said not according to bt form  hopefully someone on here can help you
Message 152 of 406
Hi thanks for letting us know this wish I’d seen it yesterday as the bt guy I spoke to said it was a fault on my iPad and I  should get in touch with the manufacturer
Message 153 of 406
Have finally manage to update to Norton in 10mins as it toke a few mins to uninstall McAfee and so far I'm not to impressed with it.
Gone is the the file shredder that I sometimes used with McAfee.
Darren
Message 154 of 406
Ney, do you have SSD or HDD that you were using the Shredder on?
Chris.
Message 155 of 406
@ChristopherPovey HDD that I was using the McAfee shredder on.
HP laptop is now a few years old. Running Windows 10.
Message 156 of 406
Switch to Norton Button does not appear.
Message 157 of 406
Thank you. This is the best response so far. We can wait for a few weeks. I have so far spent all day trying to find remaining files of McAfee in Applications or Library but no joy.
Message 158 of 406
Thank you
Message 159 of 406
Re: Important updates to your virus and password protection
How did you do it?
Message 160 of 406
Two days spent on trying to install Norton. McFee deleted. All other McFee files from Application and Library deleted. Trash bin emptied. Computer restarted.
Norton refuses to instal. Says McFee is preventing install.
