Message 11 of 32
Re: Connection to the Internet has been terminated.(Reboot,Reconfiguration,forced termination)
the only good news from the stats you posted is that the drops in connection don't appear to have affected your connection speed with actual speed just below attainable with noise margin about 6db
Message 12 of 32
Update 2.
So I did a backup of my config, then a factory reset (the option didn't work from the admin console so I had to use a paperclip)
Then I restored my config and left to soak.
Happy to report, so far, that the 5.30am and 15.30pm random reboots did not occur yesterday or this morning.
Still only seeing 54Mbps when my guarentee is 56Mbps so not sure if to cancel the engineer or not??? :shrugs:
Message 13 of 32
your max attainable was only 56mb so 54 mb connection is ok
enter phone number and post results  remember delete number but leave exchange and cab  see what the estimated speed for your connection
Message 14 of 32
Message 15 of 32
exchange and cab?  you have deleted from dslchecker
Message 16 of 32
PM'd you
Message 17 of 32
you are on an ECI cab some are getting G.INP activated and some are not.  if you are lucky and activated then that will give a boost to your connection speed and lower your noise margin down to 3db.  this is automatic and controlled by DLM
Message 18 of 32
Ok great. Thanks for your responses. Much apprecieted 🙂
Message 19 of 32
Unfortunately the issue has started again.
Relatively random disconnections again;
15:41:25 08 Sep. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
15:37:20 08 Sep. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
05:31:27 08 Sep. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
05:26:45 08 Sep. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
05:26:44 08 Sep. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
05:21:43 08 Sep. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
05:21:43 08 Sep. ppp1:Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
05:14:51 08 Sep. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
03:33:50 08 Sep. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
02:43:09 08 Sep. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
02:43:08 08 Sep. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
16:18:11 07 Sep. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
16:18:11 07 Sep. ppp1:Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
16:08:21 07 Sep. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
16:08:21 07 Sep. ppp1:Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
16:02:50 07 Sep. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
15:51:37 07 Sep. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
15:51:37 07 Sep. ppp1:Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
15:43:25 07 Sep. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
15:43:24 07 Sep. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
15:37:42 07 Sep. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
15:37:42 07 Sep. ppp1:Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
15:33:11 07 Sep. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
15:28:39 07 Sep. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
15:28:39 07 Sep. ppp1:Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
15:24:37 07 Sep. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
05:27:56 07 Sep. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
05:27:56 07 Sep. ppp1:Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
05:24:24 07 Sep. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
05:24:24 07 Sep. ppp1:Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
05:17:11 07 Sep. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
05:13:59 07 Sep. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
15:56:24 06 Sep. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
15:56:24 06 Sep. ppp1:Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
15:49:52 06 Sep. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
15:49:51 06 Sep. ppp1:Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
15:45:50 06 Sep. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
15:45:49 06 Sep. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
15:41:47 06 Sep. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
15:41:47 06 Sep. ppp1:Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
05:36:18 06 Sep. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
05:21:51 06 Sep. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
05:21:50 06 Sep. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
05:16:17 06 Sep. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
05:16:15 06 Sep. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
16:13:23 05 Sep. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
16:13:21 05 Sep. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
16:09:41 05 Sep. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
16:05:53 05 Sep. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
16:05:52 05 Sep. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
15:59:08 05 Sep. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
15:59:07 05 Sep. ppp1:Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
15:53:15 05 Sep. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
15:49:23 05 Sep. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
15:49:22 05 Sep. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
15:45:40 05 Sep. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
15:39:48 05 Sep. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
15:35:56 05 Sep. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
15:35:56 05 Sep. ppp1:Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
15:31:53 05 Sep. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
15:31:53 05 Sep. ppp1:Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
15:27:21 05 Sep. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
15:27:21 05 Sep. ppp1:Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
15:23:29 05 Sep. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
05:32:38 05 Sep. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
Message 20 of 32
I'm back with another update to this saga.
Having reset my router to factory, it continued to experience issues so I contacted BT who replaced the router.
I have just had over 1 month of trouble free internet. However, yesterday it has started again with outages in the hours of 5am and 3pm... Exactly the same thing as the old router;
15:38:33 05 Nov. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
15:33:11 05 Nov. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
15:24:30 05 Nov. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
05:15:06 05 Nov. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
05:07:46 05 Nov. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
05:07:45 05 Nov. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
16:10:08 04 Nov. :Connection to the Internet has been terminated.(Reboot Reconfiguration forced termination)
Anyone have any ideas on how to troubleshoot this further?
