Message 11 of 65
Re: Certain sites & images being blocked
Yes, it is certain websites too.
Message 12 of 65
I have tried 4G and everything works as normal, I tried even on a BT hotspot and that also worked fine, but the second I came back to my normal router, the issue came right back.
Message 13 of 65
The only real (temporary) fix is to change DNS. I changed mine to the Google public DNS which you can easily research and I can confirm that it works but I would only use it as a temporary fix.
Message 14 of 65
What's wrong with google DNS? Why only use as a temporary fix?
Message 15 of 65
I’ve been having exact same problem last couple of days. I’ve got both an iPad and an iMac. Parental controls not on and have tried using various other browsers without success. Was fine on Monday, agree with you, sounds like a BT issue to me
Message 16 of 65
Exactly the same except my problems started first thing Thursday 9th Oct.
Same as you , no parental controls touched, all devices the same , tried different search engines with the same result.
Message 17 of 65
Kevin, mine started at exactly the same time as yours, Thursday 9th Oct. This is why I feel it is a BT issue.
Message 18 of 65
Hi @TheLynxster @Kevin4 @Yorkyboy58 @DF2003 sorry that you are experiencing this issue with images being blocked. I've sent you all a Private message explaining how you can contact the forum moderation team. Please can you reply back and we'll be happy to help you with getting this issue resolved.
Check here: https://community.bt.com/t5/notes/privatenotespage
cheers
John
Message 19 of 65
Can you include me in this please?
Message 20 of 65
@JohnC2 Can you please include me in that too. Thanks!
