Message 21 of 29
Re: FTTC, not seen on bb checker
OK...had another go and this time bingo.
So filter connected to master test socket, hub connected to filter.
Hub wouldn't connect, got flashing orange light for about 10 mins.
Turned off hub, tried again with second filter, the same.
So taken filter out, replaced faceplate and tried as it was originally.
Connected albeit at a slower speed.  now:
ADSL Line Status Connection Information
 Line state:Connection time:Downstream:Upstream:
Connected
0 days,00:00:48
2963 kbps
1043 kbps
Also Wholesale speedtest,
PING
20
ms
DOWNLOAD
2.48
Mbps
UPLOAD
0.89
Mbps
So worse than I was before!
any further suggestions please?
thanks
Message 22 of 29
oh, and the stats:
Information for Helpdesk agents
When contacting the BT Broadband helpdesk, the agent might ask you for details about your BT Home Hub. This page contains all of the information they are likely to request
     1. Product Name: HomeHub42. Serial number: +076281+17250194333. Firmware version: v0.07.06.25060-BT (Type B) Last updated 17/6/20204. Board version: 01B5. DSL uptime: 0 days, 00:07:236. Data Rate: 1043 / 29637. Maximum Data Rate: 1052 / 30408. Noise Margin: 6.1 / 15.19. Line Attenuation: 25.9 / 39.510. Signal Attenuation: 26.2 / 44.311. Data sent/received: 2.0 MB / 6.6 MB12. Broadband username:  13. BT Wi-fi: Yes14. 2.4GHz wireless network/SSID: BTHub4-QPQ915. 2.4GHz wireless connections: Enabled (802.11 b/g/n (up to 144 Mb/s))16. 2.4GHz wireless security: WPA & WPA2 (Recommended)17. 2.4GHz wireless channel: Automatic (Smart Wireless)18. 5GHz wireless network/SSID: BTHub4-QPQ919. 5GHz wireless connections: Enabled (802.11 n (up to 300 Mb/s))20. 5GHz wireless security: WPA2 Only21. 5GHz wireless channel: Automatic (Smart Wireless)22. Firewall: Default23. MAC Address: 48:8d:36:84:f6:bd24. VPI/VCI: 0/3825. Modulation: G.992.3(ADSL2)26. Latency type: Fast27. Software variant: -28. Boot loader: 0.5.0-BT (Wed Nov 12 11:47:59 2014)
Message 23 of 29
that is strange as the one place you should get a broadband connection is in the test socket with a filter suggesting either faulty filters, although your tried 2, or something not right with wiring
you have a very high down noise margin as normal is about 6db suggesting scope for faster speed. If you enter your down attenuation  you will see avaerage for your attenuation
https://kitz.co.uk/adsl/max_speed_calc.php
Message 24 of 29
Right....tomorrow I’ll get a new length of rj11 cable for hub to plate and also a new filter...if the shop isn’t shut due to Covid!
Message 25 of 29
...so if from my stats ‘Line Attenuation: 25.9 / 39.510. Signal Attenuation: 26.2 / 44.311’, which of these figures is my ‘down attenuation’ please?
Message 26 of 29
OK, new cable from HHub to the test socket with the new filter.
1. Product Name: HomeHub42. Serial number: +076281+17250194333. Firmware version: v0.07.06.25060-BT (Type B) Last updated 17/6/20204. Board version: 01B5. DSL uptime: 0 days, 00:06:296. Data Rate: 1035 / 43757. Maximum Data Rate: 1064 / 43928. Noise Margin: 6.4 / 15.19. Line Attenuation: 25.9 / 43.510. Signal Attenuation: 26.3 / 48.211. Data sent/received: 2.9 MB / 11.8 MB12. Broadband username:  13. BT Wi-fi: Yes14. 2.4GHz wireless network/SSID: BTHub4-QPQ915. 2.4GHz wireless connections: Enabled (802.11 b/g/n (up to 144 Mb/s))16. 2.4GHz wireless security: WPA & WPA2 (Recommended)17. 2.4GHz wireless channel: Automatic (Smart Wireless)18. 5GHz wireless network/SSID: BTHub4-QPQ919. 5GHz wireless connections: Enabled (802.11 n (up to 300 Mb/s))20. 5GHz wireless security: WPA2 Only21. 5GHz wireless channel: Automatic (Smart Wireless)22. Firewall: Default23. MAC Address: 48:8d:36:84:f6:bd24. VPI/VCI: 0/3825. Modulation: G.992.5(ADSL2+)26. Latency type: Fast27. Software variant: -28. Boot loader: 0.5.0-BT (Wed Nov 12 11:47:59 2014)
a speed test of
PING
34
ms
DOWNLOAD
3.55
Mbps
UPLOAD
0.88
Mbps
and a silent test, nothing is heard on the wired phone line.
Now with the new cable going into the front of the master plate, into the ADSL socket:
1. Product Name: HomeHub42. Serial number: +076281+17250194333. Firmware version: v0.07.06.25060-BT (Type B) Last updated 17/6/20204. Board version: 01B5. DSL uptime: 0 days, 00:01:026. Data Rate: 1051 / 43847. Maximum Data Rate: 1064 / 44008. Noise Margin: 5.6 / 15.19. Line Attenuation: 25.9 / 43.510. Signal Attenuation: 26.5 / 48.411. Data sent/received: 0.1 MB / 0.2 MB12. Broadband username:  13. BT Wi-fi: Yes14. 2.4GHz wireless network/SSID: BTHub4-QPQ915. 2.4GHz wireless connections: Enabled (802.11 b/g/n (up to 144 Mb/s))16. 2.4GHz wireless security: WPA & WPA2 (Recommended)17. 2.4GHz wireless channel: Automatic (Smart Wireless)18. 5GHz wireless network/SSID: BTHub4-QPQ919. 5GHz wireless connections: Enabled (802.11 n (up to 300 Mb/s))20. 5GHz wireless security: WPA2 Only21. 5GHz wireless channel: Automatic (Smart Wireless)22. Firewall: Default23. MAC Address: 48:8d:36:84:f6:bd24. VPI/VCI: 0/3825. Modulation: G.992.5(ADSL2+)26. Latency type: Fast27. Software variant: -28. Boot loader: 0.5.0-BT (Wed Nov 12 11:47:59 2014)
PING
19
ms
DOWNLOAD
3.39
Mbps
UPLOAD
0.90
Mbps
Message 27 of 29
I would leave it just now as you have increased speed to 4.3mb
Message 28 of 29
So will my speed test Results start to improve from the 3.5 ish that I’m getting at the mo?
Also, one of my original questions was why apparently is my cabinet not showing FTTC service availability when my neighbour 200m further down the line away from the cabinet shows FTTC services when I check their number and gives a faster speed availability?
thanks.
Message 29 of 29
Very interesting...now when i check availability of services for my number, FTTC is there!
FTTC is available in your area.
 SpeedMaxMin
 DownStream87004700
 UpStream1200800
Also, now checking on BT, it tells me i have the option to upgrade my package to Fibre 1  or fibre 2, both in the 4-8range, min guarantee of 3.
Has someone flicked a switch somewhere?!
I know I'm on the edge of fibre availability but any slight  increase in speed would be fantastic.
My current stats are now below.  Is there anything in the stats that would suggest i wouldn't get anywhere in the range of 4.7-8.7...4.7 would be good.
5. DSL uptime: 0 days, 19:23:43
7. Maximum Data Rate: 1060 / 4076
8. Noise Margin: 5.8 / 13.5
11. Data sent/received: 306.4 MB / 5.7 GB
13. BT Wi-fi: Yes
24. VPI/VCI: 0/38
thanks,
Peter
