Message 11 of 13
Re: FTTP Full Fibre 900 upload speed capped at around 50Mbps.
Hi @Camry and thanks for posting.
Sorry your upload speed has dropped again. Can you try leaving it for 24 hours as it can sort itself. Let me know if you see any changes.
Cheers
David
Message 12 of 13
@DavidM,
BT Smart Hub-2  upload 50Mbps  speed cap now removed.
Thank you for the quick action and for the help and support.
With kind regards,
Message 13 of 13
Glad I was able to help @Camry .
All the best
David
