Message 1 of 25
Fibre 2 not showing even though my line supports it...
Hi all.
Bit of a follow up thread from my previous  post.
BT ADSL service is live and I am looking to order FTTC tomorrow.
BT checker  states 80/20 available but BT site states only fibre 1 can be ordered.
Can anyone help please? Mods maybe?
Thanks.
24 REPLIES 24
Message 2 of 25
Re: Fibre 2 not showing even though my line supports it...
My record.
Message 3 of 25
If your BT phone number is up and running then Can you post the dslchecker results
Post crossed. Is that from using phone number or address
Message 4 of 25
Yep, see last post. Thanks!
Message 5 of 25
Phone number. New BT line.
Message 6 of 25
That does not show whether result of phone number or address
Message 7 of 25
I used my phone number. But blanked it out as per the guidelines.
Message 8 of 25
I think you are going to initially Have to accept fibre 1 as offered as your bottom estimate range is below 55mb andd handback only 47mb.  If after connection your stats justify fibre 2 then maybe mods will be able to help
Message 9 of 25
Great, thanks @imjolly I will order as is then and see what my router stats say. My next door neighbour has 80/20 so no problem with the distance etc. I will follow up later...
cheers.
Message 10 of 25
Hi all.
FTTC has been setup now, and is running at my house. Router states 55/10 current connection but 76/15 maximum available.
Should fibre 2 be possible on the line?
cheers.
