Message 21 of 25
Re: Fibre 2 not showing even though my line supports it...
You need to deal with customer services, they will liaise with Openreach. Post back if you can't get any sense from CS.
Post crossed with @@RobbieMac , deal with the mods as offered.
Message 22 of 25
Hi @RobbieMac .
indeed you have summed up my situation pretty well.
I will check my private messages and respond.
thanks for your help.
cheers.
Message 23 of 25
@licquorice will do, cheers mate!
Message 24 of 25
Hi @AOtrig, thanks for your PM earlier today, and good news that you are now on the correct profile.
Cheers
John
Message 25 of 25
Yep, all good mate. Thanks to everyone for the support!
Cheers.
