Message 11 of 25
Re: Fibre 2 not showing even though my line supports it...
Absolutely!
Message 12 of 25
Thanks @licquorice  😊 👍 I thought so, but I’m still showing fibre 1 as my only option on BT’s website though. Think the mods can maybe help me here?
cheers.
Message 13 of 25
Try customer services first, if no joy with them post back.
Message 14 of 25
Will do 👍
Cheers.
Message 15 of 25
Hi guys.
Fibre 2 ordered and order complete.
Checked and the router is still capped at 55/10 it seems. It won’t sync any quicker.
Any ideas? I should be getting 70 odd / 15 according to the routers maximum available speed.
cheers.
Message 16 of 25
Can you post router stats please?
Message 17 of 25
Here you go.  
Message 18 of 25
Thanks.
When did the order complete? You are definitely still on Fibre 1.
Message 19 of 25
Tuesday this week I believe.
do I need openreach to change anything on the fibre port or can bt customer service sort it?
Message 20 of 25
Hi @AOtrig
Thanks for your posts and welcome back.
Sorry for the problems with your broadband speed.  I understand that from the outset you intended to go straight on to Fibre 2 but it was only showing Fibre 1 speeds available at that time.  Going by your Hub stats, your line is definitely capable of the Fibre 2 speeds.  I'm sorry that the upgrade hasn't made any change to your speed.
There is no need for an engineer to visit as we can remotely change your speeds to the Fibre 2 product from here.  I have sent you a private message with instructions on how you can send us over your details and we'll look into this for you. See: Private messages
Cheers,
Robbie
