Message 1 of 14
Flashing orange
My halo router flashing orange.
No hardware, physical changes.
All left intact following use of router in morning.
utilised online checks through bt app. It said need to speak to engineer. However, being new year day, nobody available.
Powered off/on.
Reconnected cables.
no difference.
bt pretty useless.
13 REPLIES 13
Message 2 of 14
Re: Flashing orange
  1. Do you have FTTP or FTTC?
Have you tried a factory reset of hub by pressing the recessed button on back and hold 20/30 secs until lights flash.
Have you checked if you have a dial tone - unless you have digital voice.
You need to phone CS 03301234150  and report the problem   you cannot speak to openreach engineer direct
Message 3 of 14
Re: Flashing orange
Thank you.
Yes, tries factory reset… still flashing orange.
Telephone calls to BT unavailable due to being a new year day.
Message 4 of 14
Re: Flashing orange
Sorry, forgot… I don’t have a telephone connected… never use one, just mobile
Message 5 of 14
Re: Flashing orange
Do you have broadband only or actually pay for landline use but just don't use it?
FTTP. OR. FTTC?
Message 6 of 14
Re: Flashing orange
I don’t have FTTP. I don’t know where the cabinet is based either.
Suspect heavy rainfall causing issues
Message 7 of 14
Re: Flashing orange
I have landline and broadband but I don’t physically utilise the landline.
Message 8 of 14
Re: Flashing orange
Don’t have fibre in the vicinity, still copper
Message 9 of 14
Re: Flashing orange
Have you checked for problems in your area?  If not just go to 'help' at top of this page
The most basic test is to check for dial tone but you will just have to phone CS 03301234150 and report fault
Message 10 of 14
Re: Flashing orange
Thanks again. No reported problems in my area. The support number is unmanned at moment, so I have to wait until they open again.
