Message 21 of 32
Re: HH6 used as WAP doesnt allow internet connection
Make sure Smart Setup is disabled on both hub and WAP. Do you have Private address - MAC randomisation enabled on your Apple device, if so disable it.
Message 22 of 32
Smart setup is off on both as is private address on apple device.
I set the dns server manually on the apple device. This now shows a a "wifi indicator" that was previously missing. However, it still doesnt give me internet and I still cant ping the router from my apple device (though I can ping other devices connected to the router).
Question appears to be why would router not send information back to apple device?
Message 23 of 32
Could you post a screenshot of both the hub and WAP Advanced Settings>My Network>IPv4 configuration please.
Message 24 of 32
Please see attached
Router page
WAP page
Message 25 of 32
A couple of things to try.
First shouldn't make any difference, but set the DHCP lease time to 21 days on the hub.
Secondly, try disabling authoritative DHCP on the hub.
The WAP seems to have a custom DHCP range and lease time set despite DHCP being set to off which seems odd.
Message 26 of 32
Lease time set to 21 days on router.
Authoritative DHCP set to off on router.
WAP DHCP custom setting - something I changed in the past but as DHCP is off I understood these had no effect.
Unfortunately - no difference.
Message 27 of 32
That's why I queried it, with DHCP off there should be nothing showing.
If you have factory reset the WAP, it shouldn't retain the custom setting either.
Are you sure you fully factory reset the WAP and set it up again?
Message 28 of 32
Apologies.
I have now factory reset WAP (and router for good measure). Screenshot of router and then WAP management page. As you said the custom settings doesnt have anything on WAP page. However, when I save the settings and go back in, the custom settings return though they are with the default setting parameters.
Unfortunately - still no luck.
WAP page after I saved and then reentered page - the custom settings reappear! though they are the same as default.
Message 29 of 32
Hmm, that shouldn't happen. I wonder if the HH6 you are using as a WAP is faulty.
Not sure if you want the hassle, but it could be worth swapping the 2 hubs over and see if that works.
Message 30 of 32
Happy to try it. Will leave it till tonight when family dont want wifi.
