Message 1 of 22
Home Hub
Hi, I would like to use my own DNS provider can this be done with a BT router.  I would like to get the smart hub 1  or smart hub 2
21 REPLIES 21
Anonymous
Not applicable
Message 2 of 22
Re: Home Hub
No, it cannot be done at hub level on either hub, you will need to do it on a per machine basis
Message 3 of 22
Re: Home Hub
Do any of the older hub allow it?
Message 4 of 22
Re: Home Hub
no
Message 5 of 22
Re: Home Hub
I have read that the Business hubs might get around this issue? But it would be good if BT can confirm this before I buy one. Thanks
Anonymous
Not applicable
Message 6 of 22
Re: Home Hub
It's a long time since I used anything older.
If I remember correctly, the hub5 allows you to select a DDNS provider from a very, very, limited drop-down
Message 7 of 22
Re: Home Hub
Interesting. The Business hub 5 was what I have been told might work as it has (apparently) a auto/ manual selection for DNS. I presume manual means I can enter my own rather than the usual drop down of five providers.
Message 8 of 22
Re: Home Hub
This may sound like a daft question, but is there anything on a business hub 5 that confirms it's a business router and not domestic. Will probably try and find one on eBay but don't want someone selling a hub 5 as a business one when it's not.
Anonymous
Not applicable
Message 9 of 22
Re: Home Hub
This is a forum for residential customers so I doubt anyone will be able to answer that.
Try the BT Business forum instead http://business.forums.bt.com/
Message 10 of 22
Re: Home Hub
Not a business customer just domestic but unable to set the DNS provider. Will see if I can register on the Business forum. Thanks
