Message 1 of 4
Hybrid connect
Can I use my hybrid connect even though I’m not with EE ?
3 REPLIES 3
Message 2 of 4
Re: Hybrid connect
Hi @Barnzy210
The Hybrid Connect is only a backup 4G modem which happens to use the EE network. It could be any network, it doesn’t matter. Your contract is with BT. The fact that BT are telling us that they use the EE network is simply so we can check the network coverage in our areas.
Message 3 of 4
Re: Hybrid connect
Oh ok thank you very much
Message 4 of 4
Re: Hybrid connect
Here are some tips from a support page about hybrid connection https://www.bt.com/help/bt-halo/getting-set-up/tips-for-using-hybrid-connect may be you will find it interesting.
