Message 1 of 7
IP Profile low after faults last week
Hi good folk,
I apologise for not knowing all the acronyms, I have been reading a lot on here before posting so I'll try 😉
I have had BT FTTC for some years and it's 80/20. When first setup my download speeds were mid to high sixties.
Since mid January 2021 I have had a complete loss of broadband fault and a noisy voice line fault (both now fixed).
Due to my downloads now hovering around 50MBps I went to the Mouselike.org and saw my IP Profile is set to 56.99
I then went to broadbandchecker.btwholesale.com and see my hardback thresholds are 65/62..
I know I might have to wait for a week or something for the line to 'settle' but as I understand I'll never achieve higher than my IP Profile 'cap' my question is (please);
Will my IP Profile raise itself or does it need resetting by someone somewhere?
I'd be grateful for advice otherwise I'll be checking every week and never getting anywhere if I should have asked for a Profile Reset 'somehow'..
Obliged for replies
Just trying to earn a living....
6 REPLIES 6
Message 2 of 7
Re: IP Profile low after faults last week
in order for the forum members to help please can you post the stats from your router (if hub enter 192.168.1.254 in your browser) and if  HH5 then go to troubleshooting then helpdesk and if HH6/SH2 then advanced settings then technical log information .
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
enter your phone number and post results  remember to delete number   https://www.broadbandchecker.btwholesale.com/#/ADSL
your profile is based on your connection speed so if your connection speed can recover then your profile will increase.  it is the speed that decides the profile not the other way round
Someone may then be able to offer help/assistance/suggestions to your problem
Message 3 of 7
Thanks do much
Sadly I'm going to struggle there;
I have the ECI version of the BT Openreach ECI Fibre Modem which I gather won't give-up that data 😞
17070 Option 2 done on corded POT - total silence.
I went to 'https://www.broadbandchecker.btwholesale.com/#/ADSL' and 'did the do'. I have a screenshot (phone number removed) will that suffice or is it a 'data dump' that's needed? (I see I can insert images? sorry)
This from you is very encouraging, "it is the speed that decides the profile not the other way round" Thanks!
(Thumbs-up done)
Message 4 of 7
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate (Mbps)
Downstream Handback
Threshold(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
Left in Jumper
High
Low
High
Low
VDSL Range A (Clean)
80
70.7
20
19
64.9
Available
Available
VDSL Range B (Impacted)
80
68.5
20
19
61.8
Available
Available
Featured Products
Downstream Range (Mbps)
Availability Date
FTTP Install Process
FTTP on Demand
330
30
Available
ADSL Products
Downstream Line Rate (Mbps)
Downstream Range(Mbps)
ADSL Availability Date
WBC SOADSL Availability Date
Left in Jumper
WBC ADSL 2+
Up to 3
1.5 to 5.5
Available
Available
WBC ADSL2+ Annex M
Up to 3
Up to 0.5
1.5 to 5.5
Available
Available
ADSL Max
Up to 2
1.5 to 4.5
Available
Available
WBC Fixed Rate
1
Available
Available
Fixed Rate
1
Available
Observed Speeds
VDSL
Max Observed Downstream Speed
58.5
Max Observed Upstream Speed
20
Observed Date
2021-01-30
Other Offerings
Availability Date
VDSL Multicast
Available
ADSL Multicast
Available
Premise Environment
Status
Bridge Tap
N
VRI
N
NTE FacePlate
N
Last Test Date
14-01-2021
Exchange Product Restrictions
Status
FTTP Priority Exchange
N
WLR Withdrawal
N
SOADSL Restriction
Y
Message 5 of 7
Message 6 of 7
from the checker results you have a 58.5mb down connection speed and 20mb up speed which should be enough for working from home  all the line problems you have had have resulted in the DLM taking action to try an stabilies tour connection by increasing your noise margin resulting in lower speed.  unfortunately as you are using a modem then unless that is unlocked you are are unable to provide the normal meaningful stats
you need to try and maintain a stable connection with no resets or drops in connection and then DLM will start to lower noise margin and increase speed but could take a few weeks
Message 7 of 7
Many thanks
"..which should be enough for working from home..." is really another discussion not best served here.
I shall research whether I can unlock the firmware of the ECI version of the modem.
For now then I am grateful to you for explaining the IP Profile will return to a higher level automatically and there is no gainful action I can take and I should see it at a higher level than the downstream handback threshold if all goes well.
Thank you
