Message 11 of 53
Re: Internet speed
This is better, sorry! B-)
Message 12 of 53
Re: Internet speed
It was actually the stats from the hub I was asking for, but the checker result was also required anyway.
Message 13 of 53
Re: Internet speed
Thank you - it's a technical challenge but interesting if it provides a solution.  Here are the stats and thank you for your patience:
Product name:
Business Smart Hub
Serial number:
+088315+NQ73512835
Firmware version:
SG4B1B0092DE
Firmware updated:
30-Sep-2020
Board version:
1.0
Gui version:
1.132.0
DSL uptime:
1 Days, 6 Hours 10 Minutes 20 Seconds
Data rate:
7.20 Mbps / 32.40 Mbps
Maximum data rate:
7943 / 38750
Noise margin:
7 dB / 8.4 dB
Line attenuation:
30 dB / 43.3 dB
Signal attenuation:
30 dB / 43.3 dB
VLAN id:
101
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
1 GB Uploaded / 7 GB Downloaded
Broadband username:
**I have blanked this out**
Public wi-fi
Active
2.4 GHz wireless network name:
BTBHub6-5PTS
2.4 GHz wireless channel:
Smart (Channel 11)
5 GHz wireless network name:
BTBHub6-5PTS
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
Message 14 of 53
Re: Internet speed
As you are using a business hub are you a BT business user?
Message 15 of 53
Re: Internet speed
neither
Message 16 of 53
Re: Internet speed
Hmm, your stats don't look particularly good, it looks as though DLM has probably banded your line due to instability, your uptime is only just over a day. Are you connected to the master socket? Is there any noise on your line with a quiet line test (17070) made from the test socket behind the removable faceplate of the master socket with preferably a corded phone. However, that said, in reality you are going to struggle to get 9M upload speed.
PS no need to blank out the username, it is generic to every hub 😀
Message 17 of 53
Re: Internet speed
@chriso57 wrote:
neither
Message 18 of 53
Re: Internet speed
it is home/domestic although I am trying to engage a job to work from home and I have until 9 am tomorrow morning to resolve it to be employed again
Message 19 of 53
Re: Internet speed
Looking at the chart, it appears that BT have set a ceiling at 7.2 mbps even though the account is sold at 6-9 and so therefore, it is an unattainable goal.
Back to the CV... thank you for your help all anyway B-)
Message 20 of 53
Re: Internet speed
Your hub stats show you are using a business hub not the residential SH2
If business hub and business user then username not generic
