Message 1 of 2
Jitter Lag during gaming
I'm receiving a very inconsistent broadband experience at the moment. I'm often getting jitter lag and low download speeds and the former is really affecting my gaming experience now where I am struggling to not get stressed out. I can get 1 jitter/lag spike an hour or 30.. on a Fibre connection. I'm a solo user on the network, using an Ethernet connection and this didn't happen at my last address using the same devices. Are there any logs or anything I can post to gather a better understanding of the issue I am having?
The following are six, back to back network speed tests.
1 REPLY 1
Message 2 of 2
Re: Jitter Lag during gaming
Hi @Numinex the ping looks ok so I would check you the internet speeds first. Would you post the results from the Availability Checker so we can check your speed estimate and also check your telephone line to see if there is any noise interference as that will affect your connection.
What Hub are you using and post your Hub Stats.
cheers
John
