Message 361 of 366
Re: MacOs 11 compatibility with Virus Protect
Thanks.  Not sure I fully understand what you are suggesting.  I went through the process below.  My Mac works on an ?intel processor and McAfee is also an Intel app so I presume I do not need to install Rosetta.  I am back in the loop of - account about to be deactivated, firewall not working, no updates
Message 362 of 366
@NH14 You don't need to bother about Rosetta unless you move to an M1 mac.
Message 363 of 366
Thanks.
So do you have the same issues following the Monterey update - ie McAfee AV - crashing repeatedly,  saying the account about to deactivate, firewall not working?
Message 364 of 366
@NH14  no issues here. Mac mini OS fully updated.
maybe reinstall? The install process should delete the old virus protect s/w and reinstate the account.
Message 365 of 366
@NH14 I don't use AV. I'm on an iMac 24 with Monterey.
Message 366 of 366
Been through this process a few times now.  Does not fix the problem
