Message 11 of 20
Re: My BT Homehub keeps rebooting
Unfortunately my router spend most of last night dropping connections every 90min or so /sadness/
Message 12 of 20
And it's doing the same all day today
Anonymous
Not applicable
Message 13 of 20
Do you have an old/another router you could try? It doesn't have to be a BT one
Message 14 of 20
Unfortunately I don’t have a spare router lying around.
Message 15 of 20
Is there anything I should look for in the logs? Any diagnostics I can try?
Message 16 of 20
I'm amazed @Anonymous  hasn't suggested the most basic diagnostic test for a dropping connection.
Do a quiet line test 17070 option 2 best with corded phone.
Anonymous
Not applicable
Message 17 of 20
Good point.
I've seen enough references to it on here so I should have thought of it. My only excuse is that I'm on FTTP with a separate copper circuit for the 'phone line, so it's not a test which applies to me when I have problems with my broadband.
That's my excuse and I'm sticking to it.
Message 18 of 20
So, engineer attended, and he thinks it's a problem with the HomeHub. He is going to recommend that it be replaced, but he suggested I contact BT too.
I can't work out from the BT website how to contact anyone to chase this up - clearly phoning is not an option. Any suggestions?
Message 19 of 20
Phoning in is the only option.
Message 20 of 20
Awesome.
