Message 1 of 5
My BT app (Android)
In the last couple of days the app has stopped allowing me to log in. I last used it Monday or Tuesday (not 100% which) to order a couple of booster discs, but when they arrived yesterday i was unable to access the app to set them up.
Phone: Samsung Galaxy A21s
Give the "Something went wrong message" and either returns to the log in screen, or closes.
Tablet: Samsung Galaxy Tab A
Lets me put my pin in, then just 'hangs' with the little green circle spinning at the bottom.
I borrowed my daughter's iPhone 12 (yuck!) and installed the Apple version,  and it worked perfectly.
Both Android versions are up to date,  but have NOT updated between when I last used the app and yesterday. I have uninstalled the app, cleaned both devices and reinstalled app, same thing. Neither device is rooted.
Your people on Twitter thought its a Samsung issue, and were unaware this is a widespread issue according to the reviews on Google Play. Was told on Play to post here.
4 REPLIES 4
Message 2 of 5
Re: My BT app (Android)
Go into the phone settings and force stop the MyBT app then try again
Message 3 of 5
Thanks for the suggestion,  but that was one of the first things I tried.
Message 4 of 5
Installed the app on to another (non-Samsung) phone, and exactly the same issue, which leads me to assume the app, or at least its latest update, is broken.
Message 5 of 5
Hi @Darkson
I'd like to take a look into this for you to see what's going on. I've sent you a private message with some details that we need 🙂
DanielS
