Message 1 of 10
Need a DLM reset
Hi All,
I know this is not standard practice but if possible can one of the openreach guys on here do a DLM reset for me. Think ive got a stuck profile. Switched from ADSL to FTTC 2 weeks ago.
9 REPLIES 9
Message 2 of 10
Re: Need a DLM reset
There are no 'OPENREACH GUYS' on this BT RETAIL  customer forum
in order for the forum members to help please can you post the stats from your router (if hub enter 192.168.1.254 in your browser) and if  HH5 then go to troubleshooting then helpdesk and if HH6/SH2 then advanced settings then technical log information .
enter your phone number and post results  remember to delete number   https://www.broadbandchecker.btwholesale.com/#/ADSL
Someone may then be able to offer help/assistance/suggestions to your problem
Message 3 of 10
Product nameEE Smart Hub
Serial number2039009988
Firmware versionv0.06.01.08190-EE (Wed Aug 19 18:20:33 2020)
Board version1
Data sent / received437.1 MB / 707.1 MB
DSL uptime0 days 1 Hours 54 Mins 38 Secs
Data rate17.52 Mbps/64.17 Mbps
Maximum Data rate17.5 Mbps/64.1 Mbps
Noise margin (up/down)5.9/6.0
Line attenuation (up/down)20.8/16.2
Signal attenuation (up/down)20.8/16.2
Broadband usernamePRODUCTIONHQNUN556643085@fs
2.4 GHz wireless network nameEE-Hub-9rNf
2.4 GHz wireless channelSmart (Channel 1)
5 GHz wireless network nameEE-Hub-9rNf
5 GHz wireless channelSmart (Channel 44)
Wireless SecurityWPA
Wireless modeMode 1
FirewallDefault
MAC addressE4:75:DC:58:E6:EE
Software variant-
Boot loader 0.0.3-EE (Mon Dec  4 17:32:53 2017)
Message 4 of 10
Message 5 of 10
Are you an EE CUSTOMER?  If so you need to post on the EE FORUM
you have a 64mb connection with an attainable of 64mb and normal noise margin of 6db  you do not need any DLM reset  your connection is ok
Message 6 of 10
@samtheaspie
Here is the link to the EE forum https://community.ee.co.uk/
You will need to post there, to get help.
Message 7 of 10
Noo im BT but using an EE router because its type B rebadged HH6.
No worries ill just customer services.
Message 8 of 10
You are not authenticating to a BT Retail server, so are you a BT Business user?
Message 9 of 10
@samtheaspie welcome back to the community and thanks for posting. Those router stats look fine and there is no scope for improvement.
The PRODUCTIONHQNUN*******@fs.  username is used to authenticate EE customers to their broadband service. If you have BT broadband it should be [email protected]
I'm not sure how that is working on a BT consumer connection if it has the wrong username.
Neil
Message 10 of 10
No idea i just plugged it in and it worked. But look its obvious what i want wont be done so dont worry all.
