Message 1 of 5
Parental Controls not working
My Parental controls are set to 'moderate' and I have blocked youtube.com.
However I can still get to youtube.com when I type in the url in the address bar.
My controls have worked ok in the past, but don't seem to be operating anymore.
Can this be resolved?
4 REPLIES 4
Message 2 of 5
Re: Parental Controls not working
Hi @fluffclark,
Welcome to the Community and thanks for your post!
I'm sorry that you are having problems blocking Youtube using BT Parental Controls.  Can you have a look at this and let me know if it helps?  -  How to block Youtube using BT Parental Controls?
Cheers,
Robbie
Message 3 of 5
Yes, I had seen that page (which is a bit out of date!), and had also used those settings...
However, despite these settings, and the report that the controls are active:
All devices connected to my broadband can still access youtube
Message 4 of 5
Hi @fluffclark
Thanks for posting back and for have a look at that link.
Sorry that the Parental Controls aren't blocking the content.  I have sent you a private message with instructions on how you can send us over your details and we'll look into this for you. See: Private messages
Cheers,
Robbie
Message 5 of 5
Thanks for letting me know this is sorted @fluffclark. I'm glad I was able to help.
Cheers
David
