Message 31 of 127
Re: Port forwarding.
No, the button on the back doesn't do the same thing, that's why I specifically said to do it that way.
Ports 80 and 443 should not be open unless you have opened them and have a web server running.
Message 32 of 127
@Jaysnp101
If I get a chance over the next couple of days I'll fix up my HH6 and have a play around.
Anonymous
Not applicable
Message 33 of 127
I'm not a gamer which is why I've kept out of this conversation but I do have an SH2 and I do use port fowarding and https://www.canyouseeme.org/ tells me that it can see the server.
Just to prove that your port forwarding isn't being blocked (as you first questioned), you could try forwarding another HTTP port, e.g. 8080 and see if you can see that open.
Message 34 of 127
Thanks @Anonymous  for your help, I will try forwarding port 8080 shortly and then check through canyouseeme if it is open or not. When you are doing the check i'm guessing you are using a device outside the lan?
I also need to check if I do factory reset using the button at the back of the SH2 instead of through the SH2 UI and start from scratch.
I understand I must seem rude at times but this is obviously annoying for me and something that should be straight forward.
Thanks again
Message 35 of 127
It is straightforward, which is why we are as perplexed that it doesn't work.
Anonymous
Not applicable
Message 36 of 127
@Jaysnp101wrote:
Thanks @Anonymous  for your help, I will try forwarding port 8080 shortly and then check through canyouseeme if it is open or not. When you are doing the check i'm guessing you are using a device outside the lan? Not always but it doesn't seem to make any difference
I also need to check if I do factory reset using the button at the back of the SH2 instead of through the SH2 UI and start from scratch. As far as I know they amount to one and the same thing
I understand I must seem rude at times but this is obviously annoying for me and something that should be straight forward. No problem but as I'm not a gamer I didn't think I could contribute anything worthwhile so I kept quiet
Thanks again
Message 37 of 127
As far as I'm aware, the UI restart is just a reboot equivalent to cycling the power whereas the physical button does a full factory reset and clears everything out.
Anonymous
Not applicable
Message 38 of 127
@licquorice
I'm assuming this is the part of the UI that @Jaysnp101 is referring to ?
Message 39 of 127
Never knew about that one, I was thinking of this one.
Anonymous
Not applicable
Message 40 of 127
You're never to old to learn  😀
