Message 61 of 68
Re: Solid Broadband Connection but no Internet/Traffic
Could be the issue, maybe a neighbour is using the same wireless channel and causing your wireless network not to work. Could be worth trying to change channels and see if that helps
Message 62 of 68
But I think if that was the problem then I would be able to connect direct to the hub via ethernet and it would work - but tried that and it doesn't
Message 63 of 68
Right at the beginning, you've been asked about a wired connection and evertime you are asked about it, you either avoid the question or today say that you don't have a wired connection and only use wireless. Now you say you've tried a wired connection. It always helps those that are trying to help you if you are honest about your setup as everyday it changes.
Message 64 of 68
I actually have said that in normal operation I have nothing connected direct, all devices connected via wi fi
I have also said that I have connected a laptop direct via ethernet for the purposes of testing if it really was no internet connection or just a wi fi problem
Sorry you missed that
Message 65 of 68
The problem isn't within your home network.
Message 66 of 68
Hi All
Fault finally identified and fixed !
Many thanks to JohnC2 and the BT Complex Faults Team
After much testing / monitoring packets, the problem turned out to be a faulty Line Card in the roadside Green Box.
What made the fault difficult to detect originally was that everyone else connected to that card did not have a problem, just me.
Thanks again to everyone who chipped in with suggestions and ideas
Message 67 of 68
Glad you got it sorted in the end, thanks for the update.
Message 68 of 68
Hi @KevG123 .
Thanks for getting back and letting us know this is finally fixed. I'll pass your feedback on the @JohnC2  and his manager for you.
Cheers
David
