Message 41 of 68
Re: Solid Broadband Connection but no Internet/Traffic
Broadband IP address:
81.157.194.160
Message 42 of 68
81.157.194.160
Thanks, I just wanted to confirm the the BT gateway router was issuing a public IP address. That does not mean that the routing is correct.
I would tend to suspect an issue with your own network, however an engineer visit should have proven that, as they would have plugged their laptop directly into on of the Ethernet ports on the home hub.
I assume that Ethernet connected devices also get no Internet connection?
I suspect that another visit is needed, by someone with a laptop, and who knows what to look for.
Message 43 of 68
I have just confirmed that I can route to your home hub  on 81.157.194.160, assuming that your broadband IP address has not changed.
This indicates to me, that there is a path from the Internet, to your home hub, so its beginning to look like an issue with your own local network. You need to connect directly to the home hub LAN port, with a known good working desktop or laptop computer.
Message 44 of 68
Just double checked and plugged laptop direct into hub and no change
Yeah, both Openreach Engineers tried their laptops connected directly to the hub
The last one was in contact with next level support whilst he was here and that's where it was mentioned that maybe either no service was being supplied by BT Retail (ceased or blocked) or there was a broadband username mis match
All connections to the hub with my devices are wifi - have disconnected them all in turn and power cycled the hub with no luck
As I said earlier, before I lost internet connection two weeks ago, I never had an issue before and all devices connected have been connected for months or years - nothing brand new added
With also trying two new Hubs making no difference, its really gonna take someone on the ball to fix this - or at least someone that has had a similar fault to fix in the past
Message 45 of 68
I still think it is an account type problem. Normally you would get a landing page if incorrectly authenticating, but maybe not in this case. The hub would still have a public IP address.
Message 46 of 68
Never heard of an account issue before that would just stop Web pages loading, but allow all other traffic, that normally only occurs if it's a local network issue
Message 47 of 68
You are going to have to leave this to the BT Mods to deal as posted here.
https://community.bt.com/t5/BT-Fibre-broadband/Solid-Broadband-Connection-but-no-Internet-Traffic/m-...
Message 48 of 68
its not just web pages not loading, for example my TV and Sky box connect to the hub but report no connection to the internet
Message 49 of 68
Yes, mods calling me again tomorrow but appreciate everyones thoughts in the mean time
Message 50 of 68
How are the TV and sky box connected to the smarthub? i.e wired or wireless
