Message 21 of 35
Re: Switch to BT resulted in 10mbps loss in download sync speed
You have to remember, noise is noise, it doesn't mean crackling static or anything else. The line should be silent with a corded phone. Anything else is noise.
Message 22 of 35
Hi
Understood, thanks. If I have to pay the £85 I will.
Jeff
Message 23 of 35
If you did the QLT from the test socket there should be no charge.
Message 24 of 35
Hi
I did, however I can see them charging me if the high pitched whine is normal!
J
Message 25 of 35
High pitch whine is certainly not normal. Only charged if problem is caused by something in your home
Message 26 of 35
Hi
BT phone engineer came today.  He changed out the test socket for a new 5C version and checked all the wiring in and out of the house, but he couldn't find anything wrong with the telephone line.   Interestingly he stated he was 'not a fibre engineer' so couldn't comment on anything to do with my broadband.
After all that, I am still connected at 10mbps less that I used to get, which is very frustrating.
Is this the end of the road?
Jeff
Message 27 of 35
Hi
No ideas at all?
Jeff
Message 28 of 35
you had a phone fault not broadband hence why a phone engineer visit  has the high whine gone now?
can you post new stats
Message 29 of 35
Whine is greatly reduced, but he said he didn't think it was an issue even before.
New stats, which are exactly the same as before:
Message 30 of 35
Any thoughts? Or is it just wait for FTTP?
Jeff
