Message 31 of 35
Re: Switch to BT resulted in 10mbps loss in download sync speed
you now need to see if after engineer work you can get a stable connection for a few weeks then banding should start to release
Message 32 of 35
Understood.
Thanks to all for their help.
Jeff
Message 33 of 35
Hi
I continue to get drop outs every few days. The most I have got to is 5 days, then my connection drops. Today was 3.5 says and it dropped, forcing me to reboot the router. When I run the BT troubleshooter, it always says 'We can't find a fault'.
After today's drop, here are the stats:
Any idea how can get a stable connection so my speed will increase?
Jeff
Message 34 of 35
Have you check the quiet line test to see if any line noise
have you tried connecting to test socket with a filter to see if that stabilises your line.
If continues to drop then you need engineer back
Message 35 of 35
Hi
Thanks for your response.
Quiet line test - yes, dead quiet since the phone engineer came and replaced lines outside.
Test socket - yes, tried that and it still dropped.
Will give it one more try and then if it drops again will seek an engineer visit.
Jeff
