Message 1 of 36
Tp link vr2800 help
Hello bought this as it says its fully comparable with bt infinity
All set up okay disabled ipv6 as was told it doesnt work with bt
All okay speeds sync at 80mb and 20mb
But not getting no were near them wired or wifi
Also if I do a speed test it knocks all my devices off ?.
When speed test finishes the devices all come back on?
Over tried qos and nothing also tried ipv6 on and nothing makes it better?
Is this a router issue or bt?
35 REPLIES 35
Message 2 of 36
Re: Tp link vr2800 help
I have the same, and although I am starting from a much slower speed, I don’t see the issues you have.
Would be worth running a quiet line test and see if you get any noise, and update the firmware to the latest version.
Message 3 of 36
Hello what's the number for quite line test
Also it as latest beta firmware I updated yesterday?
Message 4 of 36
I wondered also is there a different login details for vdsl infinity?
Message 5 of 36
17070 option 2
Use a wired phone. The line should be silent
Just the usual user name and and password
Message 6 of 36
Ok thanks try the quite test.
Have you got the same router?  Is there any settings you may have changed that in could try.
My kids said its been Terrible all day for there school work while I've been working
Message 7 of 36
It won't be a problem with the line if the sync speed is OK.
Message 8 of 36
Any suggestions on what to try?
Message 9 of 36
You could try changing wifi channel, to see if that improves things for wifi connected devices, but if you are getting problems with Ethernet connected devices as well it could be purely congestion with the world and his wife working from home.
Message 10 of 36
Speeds are up.   But still if i do a speed test on my phone or any other device it knocks all other devices off line until the upload part of the test is done?
