Message 1 of 10
is BT Cloud down?, not accepting credentials
Is BT Cloud down?, not accepting credentials
9 REPLIES 9
Message 2 of 10
Re: is BT Cloud down?, not accepting credentials
same here..
Message 3 of 10
And here.
Message 4 of 10
Same problem for me! Seems to be a repeat of the issue they had a few months ago
Message 5 of 10
 Same. Seems to go through periods of this happening. It's the only cloud backup service I use that has downtime like this. Very annoying.
Message 6 of 10
Me too - says I am not entitled to BT Cloud!
Anonymous
Not applicable
Message 7 of 10
I can login ok. Check service status in your area https://my.bt.com/consumerFaultTracking/public/faults/tracking.do?pageId=31
Message 8 of 10
Just seems to have sorted itself - can get back in.
Message 9 of 10
Hi Everyone, I'm really sorry about the problems you had accessing the BT Cloud this afternoon. I can confirm this should now be fixed and I apologise for any inconvenience caused.
Message 10 of 10
Hi - yes all seems Ok now thanks.  Only down for an hour or so. Last time was several days.
