Message 1 of 8
keep disconnecting
my BT broadband has been setup yesterday, I found that the connection keep disconnecting. May I ask if it is normal for the new setup? Does it need some time to be stable? please advise. Thank you.
7 REPLIES 7
Message 2 of 8
Re: keep disconnecting
do you have FTTP or FTTC?
are you using master socket?  do hub lights change colour?
check line for noise  dial 17070 option 2  should be silent and best with corded phone
Message 3 of 8
thanks for your reply.
I guess I have fttp.. but there is no landline here, so I cannot check through this. And yes, the colour is keep changing.
Message 4 of 8
Do you have one of these?
Message 5 of 8
thanks for reply. No, I dont have this.
Message 6 of 8
if you don't have an ONT are you connecting to a openreach master socket  which one
Message 7 of 8
should be 6
Message 8 of 8
Then you have a landline. A telephone handset for about £5 is the best diagnostic tool you could have.
