Message 1 of 9
BT Recordable TV Box issue
TV Box is not working.
Screen moves between "BT Waking Up" then after a while it moves to "youview please wait" then returns to BT Waking etc ....
It is a BT Recordable TV Box and old.
A) Tried Reboot -failed.
B) Tried "Reset to Keep Recordings" - failed.
C) Tried "Reset to Delete Recordings" - failed.
D) Tried to reset by Remote - failed as  no communication between Remote/TV Box
Hence, no other options left from BT instructions.
E) Tried "Software Reset (Recommended)" to see what would happen.
For approximately a few seconds the reset appeared to commence and then it reverted to the initial state of "BT Working" & "youview please wait" and continued for however long I left the TV Box switched on.
B), C) & E) were tried three times each with the same result.
Hence this email.
Thoughts & comments welcome.
Tags (1)
8 REPLIES 8
Message 2 of 9
Re: BT Recordable TV Box issue
That's a very old box that I don't think is supported any more.
Message 3 of 9
@valofstoney that sounds like a hard drive failure and if it is, the box is dead. If you have an active BT/EE subscription, report it as a fault and they should replace the box for you
Message 4 of 9
@valofstoney  is this a box that was known to be working  and has recently developed the problem or one that may not have not been  used for some time ?
Message 5 of 9
thank you for your input
Message 6 of 9
I shall report it to BT as I have a BT subscription. Thank you
Message 7 of 9
The box was working successfully until the isssue occurred.
Message 8 of 9
The likely  scenario as you have an active subscription  is that BT would supply a replacement loan box (probably  a later model).
Message 9 of 9
Reported and new (later model) box being supplied. Thank you
