Message 1 of 2
BT smart monitor temperature different on app and monitor
Hello,
I’ve just bought a smart monitor, and the temperature on the app and the monitor are showing as hugely different. Currently it says the room is 19 degrees on the monitor, but 24 degrees on the app. How can this be and how do I fix it?
Thanks.
Tags (1)
1 REPLY 1
Message 2 of 2
Re: BT smart monitor temperature different on app and monitor
Hi @TrueBlue87, welcome to the forum and thanks for posting.
That does seem a bog difference. It would be best to get in touch with the Product Helpdesk for guidance on this, the contact details are included in the link.
Cheers
John
