Message 1 of 8
Hi I have a BT6600 handset which will not connect to the base unit asks for pin which is unknown.
Hi I have a BT6600 handset which will not connect to the base unit, have done factory reset but still it asks for the pin which is unknown. any ideas??
7 REPLIES 7
Message 2 of 8
Re: Hi I have a BT6600 handset which will not connect to the base unit asks for pin which is unknown
Anonymous
Not applicable
Message 3 of 8
Default PIN is 0000.
Although I'm surprised you were able to factory reset without it. Did you reset base & handset?
Manual
Message 4 of 8
four zeros 0000 has been tried but does not match, still states incorrect pin
Message 5 of 8
the handset is not connected to base as it was in use elsewhere, another user had it and does not know the pin, and wasnt aware it had a pin set.
Message 6 of 8
Reset the handset page 63 in manual.
Reset the handset or base settings ....63 or page 64
Message 7 of 8
Will this work on a handset that has come from another base unit?
Message 8 of 8
@Gajo It sounds like the pin has been changed from the default 0000 on the base. You need a handset that is registered to the base in order to reset it.
Neil
