Message 1 of 14
In Smart Hub 2 Manager the 'remove' button beside devices in My Network isn't working?
In Smart Hub 2 Manager the 'remove' button beside devices in My Network isn't working? I've tried Safari, Chrome, Firefox - I'm logged in as an administrator to 'make changes'. It just highlights with a blank click and no change.Screenshot 2021-02-03 at 09.12.34.png
13 REPLIES 13
Message 2 of 14
Re: In Smart Hub 2 Manager the 'remove' button beside devices in My Network isn't working?
You can't 'remove' active (green) devices. All the remove function does is clean up the network map of devices no longer connected (grey).
Message 3 of 14
Ah, a little bit annoying as I'm trying to clean up duplicate IP's of active devices. I'll try a workaround thanks.
Message 4 of 14
Did you manage to solve this?
Message 5 of 14
Solve what?
Message 6 of 14
In the sense it's just a limitation of the Smart Hub 2 Manager; You can only 'remove' inactive devices not 'active' ones
Message 7 of 14
well I have a supposed active one but it is nothing I know about.  By the time shown on last usage I think it is the second disc locked on 2.4GHz but it is actually active on 2.4GHz.  I am trying to disconenct whatever it is on the 5.4 GHz.  Any ideas
Message 8 of 14
sorry that doesn't make sense.   Should be :
well I have a supposed active one but it is nothing I know about.  By the time shown on last usage I think it is the second disc locked on 5GHz but it is actually active on 2.4GHz.  I am trying to disconnect whatever it is on the 5GHz.  Any ideas
Message 9 of 14
Its just a list of connected/previously connected devices, you can't disconnect anything from there. All the 'Remove' button does is remove  stale entries from the list.
Message 10 of 14
But it is shown as "green" and not "grey"
