Message 1 of 12
Master socket 5c moving?
Hi there.
Total novice so reaching out and apologising for my simple questions!
I am in the process of moving into a property. It has a master socket 5C in the kitchen. This socket is a little low and will interfere will my planned kitchen renovations.
A couple of questions:
The old resident didn’t have the internet, so I assume the house is already connected and internet ready (so to speak)?
Who do I contact about moving the socket? Ideally I’d like it in the lounge. I can’t seem to find any contact details or who to contact to do this!
Any help is gratefully received!
11 REPLIES 11
Message 2 of 12
Re: Master socket 5c moving?
Your service provider can arrange this.
Message 3 of 12
Thank you for the reply
So if I’m not a BT customer, would it be Vodafone, for example, who move the BT socket? I thought it was the property of BT and no one but them could move it?
Message 4 of 12
It's the property of Openreach, and your provider can ask them to move it. There would be a charge for this, which you should be told beforehand.
Message 5 of 12
Thank you so much.
I contacted the provider and they said to contact a local electrician to move it. They would only do a ‘lift and shift’ if it were damaged. Which it isn’t. I’d just like it moved to a different room.
Message 6 of 12
That`s a bit odd, as BT Retail can raise an "Internal Shift" order with Openreach, for their customers. Its costs about £130.
Message 7 of 12
Hi did you get any joy with moving your master socket I need to have mine moved ?
Message 8 of 12
Not at all! Good luck!
Message 9 of 12
That’s a shame thanks
Message 10 of 12
Just go to local paper and get a telecom engineer and they will move socket cheaper than openreach and probably quicker as well
