Message 1 of 10
WAN Port on Smart Hub 2
I’m planning my move from FTTC to full FTTP. I’ve noticed that some illustrations of the Smart Hub 2 ports show one labelled WAN with a red label but mine doesn’t. Mine has a green phone port. Will my Port no.4 suffice or will BT need to provide a new router?Smart Hub 2 Ports.JPG
9 REPLIES 9
Message 2 of 10
Re: WAN Port on Smart Hub 2
Port 4 is software configurable as a WAN port, so you have the correct one.
Message 3 of 10
if you check in hub manager technical log information you should see switch for FTTP which you can toggle on/off
Message 4 of 10
Many thanks for your quick and helpful response.
Message 5 of 10
I've looked at Hub Manager Advanced Settings > Broadband and the option doesn't appear unless I'm looking in the wrong place?  Maybe it doesn't appear until FTTP is installed?  I'm still on FTTC.Hub Manager.JPG
Message 6 of 10
that does not look like advanced setting/technical log information where you should see FTTP toggle
Message 7 of 10
@speechless  That's an old version of firmware.
You should have v0.40.00.04147-BT
Message 8 of 10
Is there anywhere in the Manager that I can check my firmware version?  Is there any way I can update the firmware?
Message 9 of 10
does it not show in technical log information?
firmware updates are automatic and there is nothing you can do apart from leave hub connected 24/7
Message 10 of 10
Thanks. I've just been trying to anticipate potention problems before I place my order.  I'm probably worrying about things that hopefully the BT engineer will sort out during the FTTP installation process?!
Thanks to everybody who have responded with usefil help.
