Message 1 of 13
MY BT APP PROBLEM
I have stopped using the iOS app for email,  because of this problem, just  the My BT one, which works for a few days then I get this:
This has been going on for about 8 months now, and despite asking for help on numerous occasions I have not had any. I am an elderly widow, I pay more than my gas bill for the phone and plus the cost of an EE mobile service, This app doesn’t work properly on an iPad. If it isn’t sorted out when my contract ends I will go elsewhere. I don’t want to keep uninstalling and reinstalling, as I have been doing, I am totally fed up.  I use Apple Password Manager so I know they are not the problem. It can access the account ok when going in from the website, but I shouldn’t have to. The app itself is the problem, this is supposed to be a big, advanced telecommunications company. Huh!
12 REPLIES 12
Message 2 of 13
Re: MY BT APP PROBLEM
Instead of the using the MyBT app have you tried the BTMail app from the Apple store.
https://apps.apple.com/gb/app/bt-email/id1467369544
Message 3 of 13
Yes. Just stopped  recognising my password and email address on multiple occasions so I gave that up first.
Message 4 of 13
Are you presently a BT Broadband customer or are you paying for your email through a BT Premium email account?
If neither of the above your email account may have been downgraded to a BTMail Basic account which can not be used with an email client
See link
https://www.bt.com/help/email/bt-email-products
Message 5 of 13
I am a BT Broadband customer and have been for a considerable number of years,
Message 6 of 13
Thanks for confirming that for us @nanjay1.
I'm glad to hear the browser version of your login seems to be working as it should be, but I totally get that you'd want the app to be reliable as well.
Is it just the iPad that's having this issue, or do you notice this when using a phone too?
It's definitely worth checking your iPad is fully up to date too, as if this is on an older iPad OS version the app may not be best formatted for it.
You can find this by going to Settings > General > Software update, and here it should tell you your current version too.
Peter
Message 7 of 13
Another issue of unreliability with the MYBT app . Would be good if BT addressed the issue,
Message 8 of 13
Yes, I regularly upload the iPad updates when I get the notifications. I do not use my mobile phone for the apps. Just keeping in touch, mainly. My family all used WhatsApp to communicate, so I upgraded my phone so I could keep in touch better. I would never use a banking app on either device. Doesn’t feel safe to me.  It’s an IPad Pro. I used to have an IPad Air, and when I upgraded my grand daughter transferred all the data for me and I gave the old one to my nine year old great grand daughter for ( hopefully educational) games.
Message 9 of 13
Thanks @nanjay1.
I totally understand that you may not want to do this permanently, but if your phone supports the app, it's worth giving this a test on there to see if you encounter the same errors.
This can help us identify if these problems are specific to the one device, or linked to how the account is set up as a whole.
If you were to get in touch with our team, they can have a check over how everything is linked at our end too.
Peter
Message 10 of 13
Ok, will give that a go. I have visitors staying at moment, so will leave for a couple of days. Thanks.
