Message 1 of 5
BT Homeworker PON flashing after install
Hi, Waited 3 weeks for Install, OR engineer been out and installed CSP/ONT but said Its set to SASA2 not SASA1?
I believe its an exchange issue, Is anyway of getting it escalated as I'm on temp Mini hub that's 2-3mb in my area and team calls & meetings ect are painful let alone the kids battering me for youtube!
Any help would be great as I'm a homeworker.
Many thanks
Mike.
4 REPLIES 4
Message 2 of 5
Re: BT Homeworker PON flashing after install
Give the FTTP team a call 0800 587 4787
Message 3 of 5
Hi @CliffordM and thanks for posting.
Did you get this sorted? have you contacted the FTTP team as per @licquorice advice?
Cheers
David
Message 4 of 5
Hi David,
Yes all sorted, Was sorted within the hour 🙂
Regards
Mike
Message 5 of 5
That's great to hear @CliffordM . Thanks for the update.
Cheers
David
