Message 11 of 23
Re: BT Hub rebooting itself roughly every 3 days (log shows “System start Button press (PowerButton)
It was marked as the solution by a moderator.
I have unmarked it.
Message 12 of 23
The new hub appears to be working perfectly so far. It has been connected for 2 days, 7 hours, and 34 minutes without any issues.
It is running a different firmware version, which may indicate that BT has delayed rolling out the newer firmware. The current version installed is:
v0.46.02.10311-BT
Message 13 of 23
Thanks, I will try to get a new hub too!
Message 14 of 23
@omoor
Yes, that's the firmware version I've been running since early December.
The implication would appear to be that v0.46.02.42261-BT was a revision that has caused a problem and so been withdrawn.
Message 15 of 23
@omoorHow did you talk to a representative through live chat? It only let me select a few options and then asked me to call.
Message 16 of 23
I have had the same issue for quite some time, on an almost daily basis. My Hub has been replaced twice.
Recently I have been receiving this online report, which implies that the reboot is being caused by a loss of light signal to my ONT.
Message 17 of 23
Hi all,
Regarding Live Chat, I believe there was an option for Full Fibre, followed by a Talk to an Agent option.
Message 18 of 23
@omoorThanks very much. Could you help me find the option? I’ve been struggling with it, and the phone call didn’t work either.
Message 19 of 23
Hi @harry161
Thanks for coming back to the community.
You can find ways to contact our tech guides on the get in touch page, this includes an option to message us or call and the team will be happy to help.
Leanne.
Message 20 of 23
Yeah , it gave me the option to message a BT Guide, through the Live chat.
