Message 41 of 48
Re: BT and Sky affected by several issues
issue looks like its fixed. I have just received a text from BT saying its fixed so i have tested and all looks good.
Thank you to the moderators for pushing this and helping to get this resolved.
Message 42 of 48
Hi All
yes it seems to be working fine and received a message from BT saying it’s fixed. 🎉
Message 43 of 48
It looks as if it's back to normal here too.
Message 44 of 48
Hi All, thanks for the update and great news that your service is working ok again.
@suntran, is your service now working ok now?
Cheers
John
Message 45 of 48
Yup! Just checked and working fine now.
Thanks All
Message 46 of 48
@JohnC2  just for the record and interest do you know what the solution was?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 47 of 48
Hi, @Devon_Dave there was an issue with the head-end equipment in the exchange. Openreach switched the control cards to resolve the problem.
Neil
Message 48 of 48
You posted that Openreach swapped cards in the exchange!
In the bad old days of copper lines, (including FTTC), some of the Openreach Engineers were very good but most of them were Monkey See Monkey Do. - That meant that when a neighbour complained of issues the Openreach "Enginineer", (in inverted commas), sometimes swapped your line with the neighbours problem line and doing so simply moved the problems around from one set of customers to another. - I had hoped that those poor practices of swapping stuff about to correct faults had ended.
A real engineer should fault find the system and replace the faulty card with a new card, (or, if he/she is very highly skilled repair the faulty card).
Let us hope that swapped cards means that the cards were replaced with brand new cards and not swapped with other cards in the exchange and in doing so swapping the faults around.
