Message 21 of 48
Re: BT and Sky affected by several issues
Some progress then. The service I have is useless and driving me mad. Would you/anyone have a fault code for this fault, so I don't have to go through the whole process speaking to BT. I think a 4G router is required or compensation. 31st July is weeks away!
Message 22 of 48
Sorry i don’t have any ref numbers. I asked BT for compensation or to not charge me whilst this is ongoing. They told me i have some serviced and i would only be eligible for compensation if i lost my entire service.
Message 23 of 48
@Adam7  No worries, thanks for replying. Not good they can't compensate. Might have to cancel my contract next time around then. I get faster more reliable internet on 4G anyway.
Message 24 of 48
Hi @Adam7 and @slightlyslowinternet we're building a case with Openreach for this issue and I would like to get your details to help assist us with this. I'll send you a private message in a moment so you can send over your info.
Neil
BT Community Moderator
Message 25 of 48
Message 26 of 48
Please use my details that I sent by private message if you need to. I can't test my connection until the weekend unfortunately but I'll post the results then.
Message 27 of 48
Hi @Frogmodem I've already have done that but if @Adam7 and @slightlyslowinternet are still experiencing issues I'd like to add them to the case.
Neil
Message 28 of 48
Just to confirm that my connection is still (July 15) poor and some websites refuse to load.  When a site does load the little whirring wheel in the tab keeps spinning as if it's having trouble maintaining the page.  Since this problem began I have never been able to load Gmail, although the Google homepage does load. I use Edge.  Speeds are very good and I have a solid blue circle on the Hub2.  DV and my alarm system are unaffected, so I think it's an access to webpages issue.  Android and Windows devices all affected.  Using a VPN puts things more or less back to normal. Grove Park exchange needs some urgent work.
Message 29 of 48
Have the exact same issue, also SE12. As suggested using a VPN as a temporary fix. Happy to be added to the case as this must be impacting a lot of people locally and would hope is being raised as a priority to be fixed.
Message 30 of 48
Hi @suntran, thanks for posting and I've sent you a Private Message so you can get in touch with the Mod team and we'll get your details added to the investigation.
Cheers
John
