Message 1 of 3
Blue light but no internet
Hi my internet is blue light but no internet try factory reset try both WiFi and wired it been fine my 2 year old unplug it now we just got is any help please
2 REPLIES 2
Message 2 of 3
Re: Blue light but no internet
Hi @Coddgy, sorry you are having a problem with your broadband connection. If you still need help with this please get it touch with our technical team and they'll be happy to help you: Fix broadband | BT Help
Cheers
John
Message 3 of 3
If you have FTTP (Fibre) and you have a white  powers Openreach box on the wall that your hub connects to you could try powering that off for 5 minutes, power the hub down also, leave the hub off and power the white box back on, wait 5 minutes then power the hub back on.
Maybe some sort of stuck session on the fibre perhaps.
Then again if you dont have fibre this is largely irrelevant.
EE900 | Nokia ONT | Ubiquiti ER-X | EETV Box Pro (IP Mode) | Unifi CK2 | 6x Unifi U6+ | 4x Unifi SAK Ultra
