Message 11 of 20
Re: Can I check if I am capped?
I am sure it used to say up to 80MB, but now all I have is..
Message 12 of 20
I don't think I had a disconnect for 12 months until the new Halo equipment was delivered - In all that time it was also a solid 40MB, same as it is now.
Is this something I should enquire about? raise a ticket?
Regards
Mick
Message 13 of 20
Ok, thanks - yes I do so that explains it.
Message 14 of 20
I'll ask if the mods can take a look for you
Message 15 of 20
Thank you very much
Message 16 of 20
certainly looks like capped at 40mb but with attainable at 50mb even when cap removed you are not going to get more than 50mb
Message 17 of 20
Hi, @mick1966 Welcome to the community and thanks for posting, there does appear to be scope for improvement but your SNR is a little high so that could be a contributing factor to the loss of speed. I'll send you a private message and we'll be happy to check your connection and make sure you're on the correct profile for your plan.
Neil
Message 18 of 20
Information requested sent.
Big thanks to this community, fast and helpful responses
Mick
Message 19 of 20
Hi All,
I would just like to say all my issues have now been fixed, I have a solid connection with no dropouts for several days and my speeds have increased by nearly 30%.
I would like to thank @DanielS for his assistance and communications during the problems and can only recommend him as he is an asset to this board and BT.
Many Thanks.
Message 20 of 20
Hi @mick1966, thanks for your post and I'll ensure your feedback on @DanielS is noted.
Cheers
John
