Message 1 of 4
FTTP 900 Package capped at 50 upload
I just received my new smarthub  and my upload speeds are capped at 50 any fixes would be appreciated
@DavidM  @JohnC2
3 REPLIES 3
Message 2 of 4
Re: FTTP 900 Package capped at 50 upload
You need to leave it a couple of days, and it should correct itself once an update is sent to the home hub.
Message 3 of 4
There are numerous posts just like yours if you use search
Just stay connected and it should correct itself in a couple of days
Message 4 of 4
Hi @Creza, thanks for your PM to confirm that the upload issue is now fixed.
cheers
John
