Message 1 of 13
FTTP Slow Upload Speed
I've recently upgraded to BT Full Fibre and while I'm getting excellent Download speeds, I'm lucky if I hit 10mpbs Download speed. I'm using a wired connection. Any help/advice would be greatly appreciated.
12 REPLIES 12
Message 2 of 13
Re: FTTP Slow Upload Speed
which FTTP package do you have
can your run and post results   https://speedtest.btwholesale.com/
Message 3 of 13
Results as requested
Message 4 of 13
I presume it is FTTP 500 with the down speed
are you connecting ethernet direct to the hub from ONT - no powerline adapter -  using cable supplied or if not a cat 5E at least?
when was activation date
Message 5 of 13
Hi, Yes it's FTTP500. Yes to all. Activation date was 13/03.
Message 6 of 13
Just realised the cable I was using may have not been too good so I've tried again with a newer cat6 and the speeds down speeds are even better, but as you can see still terrible upload.
Message 7 of 13
have you tried a factory reset of SH2 by pressing recessed button on back and holding 20/30 secs until light flash.  if that does not fix up speed then post back and can see if mods can help
Message 8 of 13
Yep tried the reset. So yes please if you could see if the mods can help...
Message 9 of 13
Ask mods to see if they can help.  They will post here
Message 10 of 13
Hi @exercitus25 sorry your not seeing the correct upload.
I've sent you a Private Message so you can get in touch with the Mod team and we'll be happy to help you with this.
Cheers
John
