Message 11 of 19
Re: FTTP Speed?
we did have 900m for a few days now this
Message 12 of 19
Re: FTTP Speed?
You need to call CS
Message 13 of 19
Re: FTTP Speed?
yeah, just got a BOT that said all was fine
Message 14 of 19
Re: FTTP Speed?
@paul_elliott1976 have you run a speed test via the MyBT app? I'm assuming it's still there because we've not had BT broadband for a while.
Message 15 of 19
Re: FTTP Speed?
yes
Message 16 of 19
Re: FTTP Speed?
Ahh ok. Something definitely not right if that's reporting the same slow speeds as it runs a speed test to the hub. Unfortunately, you'll need persevere with CS and try and speak to an actual human. I have no idea how to get around the automated systems unfortunately.
Message 17 of 19
Re: FTTP Speed?
Could my laptop be the issue perhaps? How can i tell what max speeds it can take?
Message 18 of 19
Re: FTTP Speed?
Haven’t you tried with other devices ? .
Your laptop could ( for example ) only have a 100Mb Ethernet adapter , which will never be able to use the speed the 900Mb the FTTP connection provides , how old is the laptop ? if it’s getting on a bit , then that could well be the issue
Message 19 of 19
Re: FTTP Speed?
Possible, if your network card is only a 10/100M card rather than a GbE card.
