Message 11 of 33
Re: FTTP installed but ONT PON still flashing... HELP!
I know. I am not sure what to make now of what they have told me. Clearly something else at fault here...
But what?
Message 12 of 33
Without a crystal ball, it is impossible to tell
Message 13 of 33
What can I do though??
Message 14 of 33
Nothing except speak to the FTTP team.
Message 15 of 33
Yeah, guess it's out of my control and I will just hope the OR team can resolve it.
Message 16 of 33
Exactly
Message 17 of 33
I had same problem several weeks ago! Even BT know that usually failure to activate a line is usually the call centre having the incorrect ONT serial number. The unique number is on the front of the ONT. BT should be able the confirm the number the installer was trying to activate. Make a note of this and call BT.
Message 18 of 33
I am being told probable routing issue...
I dunno... 😕
Message 19 of 33
I seriously doubt it’s an ONT Serial Number Mismatch.
You live on a Brownfield Site so the Engineer would’ve had to physically bring the ONT and Scan it there and then on site.
I bet it’s routed to the Wrong SASA, which would mean it’s on the wrong Head End Port.
Message 20 of 33
Would that be a big job for Openreach?
