Anonymous
Not applicable
Message 1 of 7
Fibre 2 But 55/10 Profile
@DavidM
I seem to have a similar issue . I'm on Fibre 2 but was previously only able to get 50mb. Openreach seem to have made improvements & I now see a potential 64mb at my router & on the DSL Checker, but I appear to be capped on a 55mb profile. I've just given up on 150 after the call was on hold so long the batteries in my DECT phone gave up! Any chance you could take a look please?
6 REPLIES 6
Message 2 of 7
Re: Fibre 2 But 55/10 Profile
Hi @Anonymous and thanks for posting.
I'll be happy to check if there's anything we can do to help. I'll drop you a private message now so you can send over your details.
Cheers
David
Message 3 of 7
But as you can see from the checker, you are actually receiving 64.58Mbps as of today. That is an actual measured speed, not an estimate.
Anonymous
Not applicable
Message 4 of 7
Thanks to @DavidM & @PaddyB for sorting this. 👍
Message 5 of 7
Can you say what the answer was. Seems odd that the checker was showing a higher actual speed than you were receiving.
Anonymous
Not applicable
Message 6 of 7
The profile was indeed capped on 55/10 & @PaddyB kindly put through an order to lift it. So presumable the observed speed is what the line is capable of rather than actual throughput. I had a noisy line fault a couple of months back & the checker started reporting faster observed speeds shortly after that was resolved.
As an aside, I can't mark it as solved due to the following error:
Authentication failed for the action you are trying to do. This failure could be due to your browser not supporting JavaScript, JavaScript not being enabled, or trying to use the action URL directly in the browser address bar instead of clicking the link on the page.
Message 7 of 7
Hi @Anonymous
Thanks for posting back.
I am really pleased to see that @PaddyB was able to help you get this sorted.  I'll let him know you've posted back.
We're aware of the error that's happening when trying to mark posts as the accepted solution and it's being looked into.
Thanks,
Robbie
