Message 21 of 25
Re: Full Fibre 500 to Full Fibre 900
Speeds still sub 700 despite BT saying test their end shows 900 plus.  They are suggesting my PC is slowing the speed, can that bve correct?  I have an amd 15 with 32gb memory.
Message 22 of 25
What's an AMD 15?
Message 23 of 25
Sorry, it's an AMD i5 processor.  It appears that my speeds are OK despite continuing readings from my PC to the contrary.  BT tests from ther end show 900+.  I dual-boot windows and Linux and Linux reports 900+ so perhaps it's a windows thing.
Message 24 of 25
@tmarsh12345 Firstly there is no such CPU, I5 is for Intel and not AMD and secondly there maybe something wrong with your network settings in Windows, which is why you are getting slower speeds.
Message 25 of 25
it's equivalent to an i5, I'll try to be more precise next time!  What could be wrong with in my network settings in Windows?
